blondejoncherokee
- sacramento
Coming home from reno the rig had bad DW and would not drive straight. At all. Called AAA and had it towed home. its getting some new parts. Plus the exhaust was pushed into the floor with a horrible burning smell, the wipers stopped pushing water away in the heavy rain and my brake lights went out again.
Going with some high quality rear Deaver leaves and some PAC 6" progressive front coils, and some 7100s in the front for now, and some random pre runner shocks i had lying around with a massive bore for the rear with built in foam bumps for now until I can afford the 7100s for the rear.
I am also going to order a new Ruffstuff trackbar kit and relocate the axle side mount passed the passenger side coil to get the trackbar equal length to the drag link. Finally.
its hard to tell, but it seems like I destroyed the axle side heim on the trackbar already after one weekend and I can feel the clunking popping at the frame at the trackbar mount and through the pitman arm as well and the steering box. I can feel the clunk at the heim on the axle side.
It also appears that I might have taken out a pass side 7/8x3/4 FK RSMX heim as well, after one weekend. I need to do some more shaking and checking to see what is going on there.
