Woodswanderer
- SEPA
If I can interpret my own pics, I think on my '96 it is a dark brown wire.
See post #17 on page two of this thread: https://www.naxja.org/forum/showthread.php?t=1123321&page=2
A ways down in there is a pic of my wiring, including a trailer wiring adapter. The reverse lights do not go through that adapter. That leaves only the grounds and the reverse light wire that don't have to go through the adapter. The grounds are on the mounting bolts for my junction block. The only wire left is the dark brown on at the top.
Note that this is all behind the driver's tail light.
The pathetic factory reverse lights were one of the reasons that project got done.
In case you have not stumbled across it, one other way folks go about this is to install Aurora back up lights on either side of the license plate. It fits, provided you are willing to make holes in the fiberglass hatch to gain some clearance on the back side (at least that is what I understand).
Is the 99 a fiberglass hatch? I thought they switched in 95-96 from fiberglass
I didnt even think about wiring them into the trailer wiring. I dont really need to install the cubes in the back (i have led bulbs that do ok), but i want to take them out of the stock fog location up front. The idea for the seperate kill switch was so i could maybe run them as reverse lamps and rear fogs with some red Lamin-X film over them.
