831_xj
- Santa Cruz
Holy hell that's sweet man
this will not accomplish anything.
welding washers over the outer faces of the brackets will not make any difference.
SHIT. I misread that as .5
You were really 5" off from side to side? Did you have a bent main leaf?
You think those G9's are stiffer, but when you get on the road they are just going to do everything you want them to, and then make you tea when they are done.
Did you buy those directly from deaver?
I figured it was 1/2" too. 5" is insane and I never noticed looking at it. Maybe we could have seen it if there was at least one straight panel on the thing
I'm sorry, but if it solves his problem, then who cares about how the brackets were originally designed? Jons problem was that the joint/bolt was moving inside of the bracket. He welded some weld washers to the outside of the bracket, and now the bolt/joint does not move like it did initially. To say that his original problem was not fixed by the use of these weld washers is ridiculous
My whole point behind this was to help him and anyone else realize that what's more important than anything here is to make sure the bolts are fully torqued. If that doesn't work then the bracket has to be fully repaired. Welding washers to the outside is not a fix.
How the hell does yours fit the stems... I sat both ours next to each other and the stem brackets were about the same
