what about something like this?
http://www.dandcextreme.com/product_template.asp?pkID=126
i've seen drag racers come out of a wreck with concussions from hitting un padded bars in cages that help pretty well but bent down just like that one did.
Jim, you're saying these flat bar portions from the RockHard 4x4 bolt-on cage would fail?
QUOTE]
do the guys who run the T&J cage add a door bar or something to strengthen where the cage bends around the dash?
Also, doesn't a cage (especially one with a lot of triangulation above your head) make it EASIER to roll since the COG is now higher? These things aren't aluminum after all... just my thoughts. I wonder what percentage of folks with cages have rolled their rigs with them installed as opposed to folks without cages who have never rolled.
So what about removable exo cages that tie into unibody stiffeners, bumpers, and the like? I'm concerned about extra weight and unnecessary constant wind drag, so removable sounds nice. Also, doesn't a cage (especially one with a lot of triangulation above your head) make it EASIER to roll since the COG is now higher? These things aren't aluminum after all... just my thoughts. I wonder what percentage of folks with cages have rolled their rigs with them installed as opposed to folks without cages who have never rolled. For most XJ's, the worst stress point in a rollover seems to be the A pillar anyway- that thing crumples like it's made out of paper. Maybe we save weight with just a 4-point like the thread creator said. I'm no expert though, haven't had a cage yet... but I've also never rolled, although I wonder if I would have had my COG been higher due to having a cage... oy. Potential catch 22.
Yeah, having a "minimal" cage discussion in the Jeep Speed forum seems inappropriate I'll agree, because most that would hang in this forum would certainly have experience with and concerns about high speed, multiple roll protection.
But it seems to me the original poster is looking for a cage design that will provide adequate safety/protection in low speed, lay-over or single roll incidents.
In short, I think he wants to avoid having the roof collapse on his melon as illustrated here:
I think everyone here can agree that ANYTHING constructed that provides good support of the "A" and "B" pilars in a flop or roll is going to be optimal. So, yeah, a 4-point cage should be the minimum for consideration. As you can see in the above pics, the "A" pilar failed miserably. If Dutch hadn't leaned out of the door opening when it flopped, he could have suffered head/neck/spine injury. As it was, he ended up kinda pinched in the door sill area with his shoulder pressed into the roof.
I think it's pretty silly to argue the flat plate cage design of the Rock Hard cage versus a DOM tube in the same location that has 2 bends put in it. I have that Rock Hard cage and that plate is nearly 1/2" thick. It's gonna take a substantial impact to cause it to bend.
The bigger concern in cage strength - in my experience and opinion - is how it's mounted in the XJ. Building a good, triangulated/gussetted cage and having it just bolted to a sheet metal floor is the real weak point. In a decent roll/flop, there's real potential that the cage won't bend, but it could be pushed through the floor as the XJ rolls onto it's lid. I've seen some cage "feet" - foot plates and a backing plate sandwiched together with bolts actually rip the floor metal it's bolted to after a roll.
But I digress.......
To the original poster - definitely invest in a 4-point cage at a minimum. Additional gusseting and/or triangulation is a bonus. Having the cage feet anchored to the "frame" of the XJ with say, some brackets to the rock rails or frame stiffeners would be ideal. :thumbup:
So I guess the applicable question based on this thread title (asking Jim specifically), is what is the minimum non-racing sanctioned roll cage style you think would work for going fast? 4-point A/B pillar DOM connecting to brackets that are welded to the frame rails in some way? I'd like to know the answer to this too since I won't be racing and would like to save some weight if possible...
