1988 Jeep Cherokee XJ 4x4 Stroker 4.6l Auto w/ Lift and Armor - $6,500 (Chino Valley, AZ)
DZRTANK
Chino Valley, AZ
Time has come to let her go to a new home. I've had this Jeep for 17 years. Built it slowly over the years. Texting me is best b/c I don't check my messages here often. 310-403-7204
1988 Jeep Cherokee XJ Pioneer
241,000 miles (will change as it’s my daily driver)
Engine:
Golen 4.6L stroker with 15,000 miles.
FlowKooler water pump
Derale oil bypass adapter
Derale oil cooler and fan
Open Radiator Cooling System
Steering:
PSC power steering pump
PSC Gear box (ported for hydro assist)
PSC steering cooler
Brake System:
Dave’s Customs Unlimited XJ Power Brake Dual Diaphragm Kit
Transmission:
AW4 Automatic Trans
Derale transmission cooler and fan
NP242 Transfer Case
Wheels & Tires
BF Goodrich All Terrain T/A KO2 LT315/75-R16 (35” x 12” tires)
2” wheel Spacers
Suspension:
Full Traction 6.5” lift welded to unibody stiffeners
Bilstein Shocks
Front Axle:
Superior Axle Super 30 kit (30 spline heat treated)
Superior Axle 4.56 Ring and Pinion
Auburn Gear ECTED E-Locker (Limited slip full time. Locker when engaged)
Rear Axle:
Superior Axle Super 35 kit (30 spline heat treated c-clip eliminator)
Detroit Automatic Locker
Front Bumper:
Hansen XJ Prerunner bumper kit.
SuperWinch 10K Winch w/ Steel Cable
1 Pair of LED 3” cubs
1 10” LED Spot Bar
Rear Bumper:
Hansen XJ Tire Carrier Bumper
Protection:
Rock Hard 4x4 Roll Cage (welded to stiffeners)
Welded Unibody Stiffeners
Rocker Guards Welded
Rusty’s Front Steel Fenders
PureJeep Rear Quarter Panel Protectors
Pure Jeep Gas Tank Skid
Pure Jeep Trans & Transfer Case Skid
Hi-Lift Jack
Other:
PowerTank – 20 lb
12V Disconnect
Optima Yellow Top Battery
New Carpet
New Window Seals
Moon Roof
SnapOn Computer Scanner
A/C blows cold
Louvered Hood Panels
The Bad News:
PSC Gear Box has a leak.
No Radio
No Headliner
Heater Core is bypassed due to a leak. I have the core, just need to install it.
Linky no workee.
The link seems to have been to your own listings page on C/L. It wants a log-in. Might want to try again, looking at the C/L post without being logged into C/L.
Linky no workee.
I found it!
Stroker is still running on the Renix ECU?
New link - Reduced price. Text me with any questions. I don't get on here as often as I would like. 310-403-7204 - Clay
