DutchVDub
- Milliken, CO
Not beyond the barrel, around the barrel.
In these picture you can see how far the barrel sticks past the SG-Works stock
With my flash suppressor my barrel is 8 3/4" or so beyond the piston tube (seems to be about where the SG Works stock ends).
I am wanting the rails to go out just behind the bayonet lug. I am picturing ssomething like an OD tubing clamp with threaded lugs sticking out of it that the rails can bolt to. The clamp would be atttached to the barrel itself just behind the bayonet lug (my bayonet lug is behind the sight post like in the top picture). Then I would also cut the majority of the factory sight post down as its no useable with the cconversion.
