Lincoln said:Should we start taking bets on if he will get it put together before wanting to change it?
I bet he's already got the 1610 (he really should) rolling around in his head.
Blow me. Don't you have some campaigning to do?
cal said:Kingpins -have- to be better .. I mean, the kingpin bearings on my f100's dana 44 usually last a good 18 to 30 months before i have to replace them.
Granted, I've driven the truck 21k miles in the last 5 years .. but still. I have a balljoint front end going in to fix that..![]()
cracker said:Blow me. Don't you have some campaigning to do?
CRASH said:Usually the balljoints freeze up long before the BJ's go, though.
Mike L said:Isn't a ball joint the same thing as a BJ? :laugh2:
-Mike
GSequoia said:What happens in JV stays in JV?
cracker said:Still doesn't explain why comp 2500# buggies change their ball joints so often :lecture:
BIGWOODY said:I've seen broke BJ's on a 60...I've yet to see or break a KP myself.
David Taylor said:Was this after a u-joint going ? Or, did the ball joint just fail on it's own.
Paul S said:Have you ever seen a broken BJ that wasn't caused by an inexperienced driver thinking it was ok to drive on a broken axle/ujoint?
People say the same about D30 BJ's, of which I've seen a few break, but never without driver error as the cause.
Considering how long BJ's last under D44's running 37's, & I'm sure D60 BJ's will years under 40's.
In the meantime, Avery's going to be reshimming his springless KP's every month in a futile effort to rid himslef of death wobble, after a year or so he'll give up & try running the stock KP springs (as they were designed), of course we know from countless KP complaints that this will not solve his DW problem.
It's cool Avery, you can drive out to Hwy 20 & Outer Limits with Garry, he'll be the guy maxed out at 23MPH. We'll wait at the trailhead:wave:
P
DW is soooooo 2003. I've never met a DW problem that hydro assist didn't take care of, not mention all the stress it takes off the track bar. Better yet full hydro, I can run the buggy at 70mph, on 39 krawlers with no balancing (water , bb's etc..).For the street and trail , there's no beating assist.Paul S said:of course we know from countless KP complaints that this will not solve his DW problem.
P
BIGWOODY said:DW is soooooo 2003. I've never met a DW problem that hydro assist didn't take care of, not mention all the stress it takes off the track bar. Better yet full hydro, I can run the buggy at 70mph, on 39 krawlers with no balancing (water , bb's etc..).
