I have an XJ dana 44 and am trying to get the parking brake working. The used axle came with no brake parts besides the backing plates. If someone knows of a new PN for the brake strut or has a dana 44 and looking to do a disc brake conversion I would love to buy some of your old brake hw. But Ive found these axles relatively hard to come by so my second hope with this post is to be informed of one dimension being the the length of the strut, specifically item #5 identified as PN 8350 4372-3 in the assembly diagram.
I cannot find this PN available online and instead acquired Omix-Ada PN OMX-1675106 from another jeep dana 44 application hoping it might be close. This suspect part is about 5.75 inches between the insides of the opposing notches (ignore the parallax from the pictured view).
After assembly with all new parts, it seems like the lever is reaching the end of its travel range with parking brake applied before the strut is able to start spreading the brake shoes. The adjuster is appropriately set for the shoes and drum interface but it seems like the strut needs to be about 0.25-0.5 inches longer for the lever arm not to be maxed out on its travel before starting to spread the shoes. With the correct dimension in hand I could even just fabricate a part.
