- NE Indiana
We are taking a year off from mission impossible.
mac 'want it to be special' gyvr
Making room for those 35's? I can't wait to see it in person. I want 35's so bad.
Im hoping to make it this year. If so the jeep needs.
Drivers floor pan patched Not going to happen
Reseal the front axle Pinion and carier in, Still need to put axles and whatnot together
Front Ujoints Done
front brakes Done
Cb work Todo
LOF Todo
The Maybe list
Front axle brackets Not gunna happen
lower control arms Not gunna happen
Drivers window regulator Not gunna happen
Already fixed.
Tailights and turn signal wiring
Originally Posted by emptypockets86
-Tow vehicle capable of getting there and maybe back if I'm lucky. - DONE
-Something better than a tent to sleep in or at least a better sleeping bag.
-Steering upgrade
-Stiffeners welded in - DONE!!!
-New belt - DONE
-Install starter drive - DONE
- trans pan gasket
- pinion seal on 8.25
- oil change
- axle shaft u-joint
- spark plugs - DONE
- gear box - not doing
- oil pressure sender
just made myself a list today
-find a spare tire
Drivers floor pan patched Nope!
Reseal the front axle Done!
Front Ujoints Done!
front brakes Done!
Cb work
LOF Done!
The Maybe list
Front axle brackets Possibly
lower control arms Possibly
Drivers window regulator Negative
Already fixed.
Oh lets see how long the list is this year.
Jeep:
fix rear driveshaft DONE
Fab and install rear traction bar NOPE
Find some 6.5" leafs DONE
Install t/c skid MAYBE
Rear disc brakes or new shoes THIS WEEKEND
Grease and fluids THIS WEEKEND
Van:
Replace all rear brake parts DONE
New front pads NO NEED
New shocks DONE
Maybe some new leaf springs NOPE
New steering gearbox NOPE
New tierod ends DONE
Get an alignment THIS WEEKEND
Oil change DONE
I need to install my xj engine skid on the tj.
3 link the front
And install my cb
-finish rock rails
-trim fenders DONE
-trim bumper DONE
-replace both unit bearings DONE
-take out trail spare axle shafts and install new shafts/ujoints DONE
-paint bottom half of jeep
-probably extend bumpstops
-find a spare tire
Put tire back on Done
Rebuild spare rear driveshaft Done
Install rear driveshaft Done
Fix the cigarette lighter for the CB
Scrounge up a better spare Done
Double check fire extinguisher and first aid kit Done
Load jeep and spare parts.......atriot:
Ummm......unless I make a serious break through on my front axle noise I just need to throw my tent, cot and clothes in the Neon and gas up....
Jeep:
Mount Hi Lift. Not happening
weld in mid stiffeners and 2x6 rocker replacements with tie ins that have been collecting rust in my garage since last WF. alo not happening
Install CB, fire extinguisher and new battery tray. This weekend after I get the little jeep running.
Tow Pig:
Change ball joints, build partition so I can shut Walt up on the way down if I want. Ball joints were ok, changed out pass. side wheel bearing. Don't need partition because Walt's gay and isn't going.
[/QUOTE]
I'm lazy but I'm going to WF!!!!
I made a nifty little bracket so I can stop flying my ghetto flag. Was it on my list? Nope. Haven't done anything I should be doing.
