What ya gotta get done before WF?
Im hoping to make it this year. If so the jeep needs.
Drivers floor pan patched Probably not going to happen but stil hoping.
Reseal the front axle Rebuild front axle= tore apart. Waiting on shims
Front Ujoints Done
front brakes Done
Cb work
LOF
The Maybe list
Front axle brackets Recieved
lower control arms Pending axle brackets getting welded on
Drivers window regulator Probably wont happen
Already fixed.
Tailights and turn signal wiring
Not on original list
Crankcase vent hoses
1. Install locker(s).
2. Fix/Find a tow rig.
JIM.
I've got a lot of stock steel wheels, we can mount at the campground. $15
Thank you very much, I am looking for a Ford ranger/explorer wheel with i think 4" bs. I will let you know before WF if I still need one.
-Replace busted yukon shaft----DONE
-Repack wheel bearings----DONE
-Replace caster bushings----not happening
-Ditch piece of crap ballistic joints in favor of ruffstuff 1.25 heims----also not happening
-Replace assist lines----still not happening
-Frame stiffeners----too cold to lay on the driveway
-Maybe some sort of rocker protection, probably not...----I was right
-Rewire winch---maybe, see how the weather is next weekend
-New muffler----I did do this
-New amp so I can jam out----Looks like I'll be using the cassette player
-and a blower resistor----It bothers Kelly more than me, she can do that :)
Getting an alignment done at the end of the week (the previous place didn't tighten a part and it is popping. Will have the diff fluid changed when I get my taxes. After that, once I get the oil changed, I am ready basically. I should get a second fire extinguisher and need to find some d rings, but that isn't required.
i'm not quoting my list, it makes me depressed every time i see it. got the spark plugs installed over the weekend. I also removed a whole bunch of useless vacuum hoses and related emissions junk that no longer worked. hoping to burn in the stiffeners this weekend. wish the weather was nicer, spent yesterday night lugging a gas tank into a f250.
Anyone wanna donate some fab help to get me rolling? Not looking good at this point.
Put tire back on Done
Rebuild spare rear driveshaft
Install rear driveshaft
Fix the cigarette lighter for the CB
Scrounge up a better spare Done
Double check fire extinguisher and first aid kit Done
Load jeep and spare parts.......:patriot:
Register for WF & Membership Done
Jeep:
Frt & Rr Diff Fluid Changes DONE
Install New Frt Axles Seals DONE
Install Frt SOLID Diff CoverDONE
Tcase Fluid Change DONE
Tcase Planetary and Chain swap from Chevy 231 Not Now
Install TnT 8.8 Truss If I get my Big Welder Working Before WF
Bed-line Rear Wheel Wells Need-to-doHalf-way There!
Patch Holes where I just Cut the Rear Lower Quarters Off Need-to-doHalf-way There!
Modify Rear Bumper to Include Wrap-a-round Guards If I get my Big Welder Working Before WF
Find Spare Parts (Axle shafts, Frt Drive shaft, etc)
Find Full-size Spare Tire DONE
Tow Rig:
Oil ChangeNeed-to-do
Find P.S. Leak & Fix Not Now
Trailer:
Find Trailer & Secure Use for trip Need-to-do
Put in new t-case Done!
Regear front Done!
Make sure its not gonna explode Still to be determined
Fix CB Needs a better ground
Put new reflector housing on my broken lightforce Done!
New exhaust Might have to wiat
Drive to Byron's to get my other driveshaft Still need to do this!
An alignment to fix an issue with my steering, got the oil change done this morning. Wasn't that cold in the garage with the door shut.
