bhicks
- Forest Falls, CA
I am okay with buying two more boxes but my total will push me up to $150. I am definately going to need some reimbursment, unless we can get two other guys to each pick up one pack of 12.
X3 about reusing, especially if Julio uses it before me!
I might pick up a box of 12, maybe someone else wants to pick up an additional box?
Can you not just dig a cat hole off the trail?
It never re-opened. The 120 day closure turned into a permanent closure, and the area between Little Sluice and Spider lake was our favorite wheeling area on the 'Con, and Spider Lake was our favorite place to camp. The closure was due to human waste and overuse. Unfortunately, most of the trail is on rock with a little dirt covering in areas, and with as many people as run the trail, the poop and paper situation can get out of control. This is why everyone is asked to use their own toilet system. Friends of the Rubicon has been giving out cardboard PETT toilets and WAG bags to try to educate folks.
There are some outhouses along the trail if you know where they are, like near the first creek crossing, near the top of Walker, at Buck Island, etc. However, some of them the Forest rangers prefer you not to use (like the ones at Buck Island) since they aren't really legal. There are quite a few outhouses at Rubicon Springs, and that's private property so there are no issues.
If you're plan is to go all the way to the Springs your first day, and camp there a couple of days, you probably don't need the PETT.
Jumper cables and welding rod? lol
Jumper cables and welding rod worked to get Remi all the way home when his front axle tube split all the way around on the 'Con in '04.
I always carry cables,rod,and goggles with arc. welding lens. And they have been used many times. Remi welded the Knuckel up on the Sleigh one time and I drove out. A couple random short pieces of angle iron can help to field fab parts as well.Jumper cables and welding rod worked to get Remi all the way home when his front axle tube split all the way around on the 'Con in '04.
Oh, no...who invited Sean?Looks like I'm in guys!
So yea, Not sure if im going to make it
