Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Well I actually have three vehicles, running, right now. My sons 96 Ford Taurus which he bought in Dec '06, V-6, 3.3 l, 179,000 miles, got 10W30 on the first oil change, then went to 10W40 on the second and third for summer time here. It's doing fine.bewilderedbeast said:Me? Self-conscious? Guilty? Not even. Just wondering whether to respond to your post or not.
As I said, the Chevron dude says the big uproar about zinc is misplaced.
As for the heavier oils, have you thought about Delo in 15W40?
Then I have an '82 Nissan SD-22, 2.2 L, diesel engine in my 85 Cherokee Pioneer, which has been running 15W40 Shell Rotella T for 5 years now with no problems, mileage unknown! I will be switching to Mobil Delvac 1300 Super for the Nissan in 3 months, because that is all I could find, and all I have left of the non-CJ-4 spec oils for now.
I may try the Mobil Delvac 1300 super (I have 4 gallons to try now), 15w40 in the 87, 4.0 Wagoneer ltd. (4x4), but I am sure I will end up boosting it up with Lucas (qt) and some CD-2 Slob (pt) I recently scored at BigLots (sounds like a drug fix, LOL) since the Lucas is devoid of ZDDP.
I looked real hard already, but could not find any Delo at all on the shelf that was not already CJ-4/SM so I setlled for Mobil. I have never heard anyone that used Mobil 1 oils that did not like them, so I figured maybe the Mobil Delvac would be OK too.
What I am trying to figure out is why it drank 20W50 Castrol Syntech so fast. And there was absolutely no smoke in the exhaust. I was originally running 10W40 Exxon dyno and only using a quart in 3000 miles when the hot oil idle pressure problem popped up last year (9 psig). Since then I started adding Lucas (which has worked great, even quited the lifter ticking noise) to solve the oil pressure problem since the new bearings and high flow oil pump had little effect on the hot idle oil pressure. But then I tried 20W50, castrol Syntech to that would solve the hot oil pressure problem, and boom It was using 1 qt/200 miles and that was AFTER I fixed the massive oil filter adapter o'ring leak. Added 1 qt of Lucas and later 1 qt of straight 50 Exxon dyno juice and no more worries. So right now its got about 2.5 qts of 20W50 Castrol Syntech (SM), 1 qt of Lucas, 1 qt of Exxon 40 wt and 1 qt of exxon 50 wt all mixed up in there..
Why are you so down on Mobil, other than it's synthetic?
