- MilkyWay Galaxy
STP volume is a lot higher, not lower, and the STP seems to be way too dilute in ZDDP content to do squat for us.So add full bottle or half of it to oil to make ZDDP right?
(STP blue bottle is half the volume, and the PDF says ZDDP will be raised to 1700 ppm when whole bottle is used with 5 quarts of oil)
Looks like 2 oz of the 4 oz bottle of the ZDDP Plus product would be plenty to make an API SN oil equal (or higher) in ZDDP content to the old API SL oil spec. 4 oz would take you back to at least the 1980 levels of CH oil spec, pre SL spec, but final ZDDP level will depend on the SN ZDDP content which could be 0 to 600 ppm I think? I have read that unless you are breaking in a new engine or CAM you should not go over 1800 ppm. So for daily driver use, I would not add more tha 2 oz of the ZDDP plus, unless I knew the oil I was using had no ZDDP in it all!!!
