Ol Blue
- Arvada, CO
I finally got around to doing a Blackstone oil analysis on my 2001. I use Mobil 1 10W-30 Full Synthetic High Mileage and run the recommended amount of Seafoam in the oil a few days before the oil change. It has 147k miles and runs great. Thought the test would be for peace of mind and was curious about wear metals. Turns out they found coolant in the oil with the high potassium (496 ppm) and sodium (294 ppm). Also wear metals are pretty high. This really surprised me because it doesn't overheat, doesn't smoke, no milkshake in the oil, no oil in the coolant, and here's the kicker...it doesn't (noticeably) use coolant. I've owned this for 3 years/13k miles and never had to top off coolant. As long as I've had it oil pressure has always been on the lower end but seems fine (12-13 psi hot idle but up to 30-40 psi driving).
Current coolant level is halfway between Full and Add. Roughly 2 years ago I did a coolant flush and fill. Can't remember where I filled to but I'm assuming I filled to the Full line. So that would be a consumption of Full to halfway above Add in a span of two years, assuming that none evaporated. This XJ is not a DD, its mainly a winter beater when it snows and trail rig.
So how concerned should I be about this? Any thoughts on how long it will run like this? I'd hate to dump money on a new head with the high mileage and damage likely already done to bearings (lower oil pressure and high wear metals). Kinda tempted just to do short OCIs and save for a stroker at this point. I have to pass Colorado emissions so a stroker is really my only possible engine upgrade.
New item by Steven Freytag
photos.app.goo.gl
