WilliamT1974
- Tennessee, USA
I have a 1996 Cherokee Country with 303k miles on what appears to be the original drivetrain. For the most part, I've felt pretty confident that I can take it almost anywhere. I've owned it since January of 2021 and have done quite a bit of work on it to make it a better driver and have kept up with its maintenance. I got very little information about its history from its previous owner.
Shell Rotella oil seems to be popular in the XJ community for higher mileage engines because even though it may have the same viscosity as an oil made for gasoline engines, it's "thicker" and may help to keep the engine quieter and the oil pressure higher. My engine has a bit of a growly, piston-slappy sound when cold started, but it gets quieter as it warms up. That said, it's never completely quiet. I'm not afraid to drive it, but it may be showing its age. Also, after a freeway ride on a hot day, when I hit the first stop sign or traffic light, the oil pressure gauge goes really low until I start rolling again. I know from a technical standpoint it's within acceptable limits, but it sure looks odd. The most oil I've ever seen it use was getting to the halfway range of the Safe marking on the dipstick, and it's only done that one time in my ownership, so it's not using much oil. It may go down about 1/4 of the Safe range in between oil changes.
So, last oil change a little over a week ago, I decided to use Rotella T6 10W30 in it, along with the Mopar oil filter whose number ends in 090. Six quarts and I'm right at the top of the Safe range on the dipstick. The engine may be a little quieter, and the oil pressure gauge does read higher even after a hot highway run.
We had some really hot days over the last couple of weeks, and it has cooled down and feels more temperate since the middle of the week. But over the last couple of days, I swear I'm hearing pre-ignition in certain driving situations. While it could be bad gas, this doesn't seem probable. I use Top Tier maybe 70% of fill-ups. I know that's more a function of detergent rather than octane or quality, but it has to count for something. But the reason it's a concern is because it hasn't happened before. The oil is the only thing I've done different recently. I hate to be wasteful, but I'm tempted to drain it and just go back to using SuperTech High-Mileage synth or regular 10W30. Nothing wrong with that oil. It's made by Warren and has to pass the same tests that the brand-names do.
Any thoughts? I hate hearing that pinging sound and know how bad it can be for the engine, so anything to get rid of it would be great. But the only thing that seems different is the oil.
Thank you,
-William
Thank you,
-William
