RWKHausSupply
- yorba linda, Cali
Just do a full C pillar hoop (copy of the B) and then just run typical to what you have now back from that.
Rawbrown said:I had question, Dave, Paul, Goat and capt. about what size fuel cell to run. 10-12 is doeable. I'm looking at the 12Gallon cell from Jaz products. measures 17.5L x 16 W x 10 H. the next step down from Jaz is 8 gallons. There are probably others out there, but Jaz makes em clear if you want. Also, sink the fuel cell down in between the frame rails, that will clear the diff. That should keep the COG lower. But leave the roof as it is. I should be right behind you as soon as I can get some $$$ for the tubing.
ROBERTK said:So whats going on? Did you give up?
Mr.OverKill said:GET YOUR ARSE TO WORK!!
if you and your wife aint at the river with me and my wife then you better be worken!!![]()
Rawbrown said:before the socalXJ Jambo back in march, I had proceeded to remove the hatch, doors some sheet metal and a few excess things. I went to the scales with a full tank of gas and the spare mounted. 3500# is what my jeep weighted. It was stiff in the back and didn't flex very well. after removing one select leaf from each pack, I got my flex back and the ride as well. being that I don't plan on carrying a spare when I step up to 37"s, my goal is to keep my jeep under 3500#'s. I know Ricks jeep pretty well since his build is very similar to mine. He will for sure have to pull a leaf out of each pack.
ROBERTK said:I agree with the raising the tank.
But I dont know about removing a leaf. Maybe if they were higher rate and stuff to start. But my FT jeepspeed rated leaf packs are great as they were when it was full bodied. I think that with the tube and a full size spare and a decent selection of trail tools and small spare parts, it more then makes up for the rear doors and hatch and glass. But I could be wrong.
