Located in Lakewood, CO 80232. Selling on Facebook Marketplace - https://www.facebook.com/share/1DJ5RsTpr1/
$3,500.00 ; OBO
1993 Jeep Cherokee (XJ) Country 4x4
Purchased in Boulder, CO July, 6th 2012 with 118,305 miles from original owner with complete service records dating back as far as 1995. I've owned "Todd" for almost 13 years and about 100,000 miles. Like its original owner, I've kept this Cherokee in mostly stock OEM condition and used it as a daily driver.
Factory Features:
The service highlights below were all in preparation for a long-form road trip that ultimately didn't include the Jeep. I've kept the jeep garaged since completing all the work, however the house (and it's garage) is listing on the market next week and it no longer makes sense for me to keep it around.
Professional Technician Completed Service Highlights:
Personally Completed Service Highlights:
Upgrades over stock (hyperlinks included):
The Good
The Not as Good
$3,500.00 ; OBO
Factory Features:
- Power Steering, Power Brakes, Air Conditioning, Tow Package Upgrade
- Two tone paint (Red x "Champagne Gold")
- Cloth & Vinyl Upholstery with wood accents
- Lace Spoke Wheels
- Upgraded Chrysler 8.25 rear axle
- Transmission cooler
- Complete bottom end service of the engine block, by High Octane Performance in Lakewood
- New connecting rod bearings, upgraded high flow oil pump, oil filter adapter, oil pan gasket
- New torque converter, flexplate, rear main seal, transmission line clips
- New front drive shaft U-Joint
- BG Air intake kit and service
- BG Fuel Injection service
- Cylinder compression test (all cylinders tested within 4 PSI of each other and above 120)
- Annual to semi-annual use of lifetime alignment, balancing, and rotation with Firestone Complete Auto Care
- A/C drain and servicing, R-134 freon replaced with new cans I was able to source
- New spark plug wire set, cap, & rotor, spark plugs (NGK V-Power Nickel Plug Number ZFR5N)
- New brass constructed fuel pressure regulator, new o-rings
- New serpentine belt
- New Duralast Gold Starter
- Cleaned and serviced throttle body with new gasket, removed and cleaned air intake manifold
- New IAC, TPS, MAT and MAP sensors, new CCV breathers, new vacuum lines, new WIX Panel Air Filter
- Removed and replaced radiator for full service and cleaning, new radiator cap, all new coolant hoses and clamps, thermostat, therm housing gasket, coolant temperature sensor as well as coolant sending unit
- Front and rear differential cleaning, inspection, and fluid change with new housing cover gaskets
- Full brake system refresh including new drums, rotors, calipers, pads, all hardware components, and even brake cylinders on all 4 wheels, brake system bleed with DOT4
- Recently replaced engine mount bushings and transmission mounts + bushings
- Recently replaced Ultima 90 amp alternator
- Recently replaced front sway bar, mounts, and bushings with new 26mm Dorman kit
- Recently replaced tie rod ends and stabilizer bar
- 20k miles on replaced upper and lower ball joints
- JB Conversions fully upgraded NP231 Transfer Case (wide chain kit, 6 pinion planetary gear, and master rebuild kit)
- Brand New Super Start Platinum AGM Top Post, Side Post Battery Group Size 34/78 750 CCA 120 Minute RC
- Brand New Firestone Destination X/T OWL LT30/9.5R15 C104R tires professionally balanced, aligned, and installed
- Front & Rear Floor Liners, Color matched to tan interior
The Good
- The interior is in pretty good shape and even includes a new headliner, though there are some signs of wear and some faded oil spots in the back cargo area
- Quite possibly the cleanest engine bay, head, block, and underbelly that exists right now. The engine sounds amazing and shows great health
- Any trail time was only ever to access backpacking trail heads. The result is a very clean and very well preserved XJ.
- Absolutely zero death wobble or alignment issues
- The full service brake job was done in connection with putting on the larger tires
- Over-powered battery installed to accommodate future custom auxilary components (lights, gauges, etc.)
- Super classy two tone exterior color
- No rust, no leaks, control arms and bushings still in great shape
The Not as Good
- The transmission's fluid pump... It's making a noticeable whine. It happened shortly after the bottom end work completed by High Octane Performance. The second opinions from various trans techs tell me that the input shaft isn't aligned fluidly with the trans fluid pump. So either the transmission is re-mated to the engine correctly and the pump is still operable or it needs to be swapped. Looking through the forums, it also looks like a lot of y'all don't mind the whine and continue to drive without any issues.
- Cracked windshield
- Fading clear coat on hood and roof, some paint discoloration on the bow of the roof
- Center console lid needs to be reattached to hinge plate
