Jump This
Just another minion!
- Borrego Springs Ca.
![shocktowers.jpg](/proxy.php?image=http%3A%2F%2Fi121.photobucket.com%2Falbums%2Fo220%2FJump_bucket%2Fshocktowers.jpg&hash=cbc579b85d09e3de527de6a6471d663f)
Shock towers are completed. Waiting for control arms and steering...
Coming together rick, how much more time do you think?
Have you ever got that 2 door on the road?Transmisson right?
This is what I need. Anyone know who might be able to fab up another one?
What I had decided to do is have my front lowers the same length as the back lower control arms so I'd only need one spare (36" eye to eye.)
What that ends up doing is having the mounts equal with the stock cross member. Although I have already built a strong, flat belly, cross member, there is no protection for the t-case or tranny (yet.)
If I can find something like this all I'd need to do is add the control arm mounts and it would be done.
Jump this, I can make this for you no problem. The only issue is laser time would be out a few weeks.... But I could even have a full skid and control arm mounts cut up, ready for you to weld where you desire.
Just a thought.
Just run some 1X1X1/4 angle on the leading and trailing edges , it is stronger in the ^ position than square tube
Hot new trend: angle steel control arms. In the ^ position, of course.
Even cutting plate that thick, and leaving a clean line, is difficult without proper equipment.
Angle grinder + cutoff wheel. That's how I did all my brackets; here's what's left.
Pretty easy to cut nice straight lines that way.
April says spray paint it flat black, sling some paint at it from a distance, make a stand and list it on Ebay as "Abstract Art". Starting bid $2,500.![]()
Plasma cutter with a guide is nice with a guide as well with more clean up though.
