- Westminster, SoCal
You meen Green River?xjohnnyc said:I've also decided to go up Saturday morning in order to avoid the Friday night traffic. Remi and I are meeting at the Green Valley exit at 6:30 am.
desertjeeper said:Does anybody know if Hwy 18 is open yet to come up from Lucerne Valley or if I will have to drive all the way around to the San Bernardino side?
Meeting for the trail runs will be in the discovery center at 9am on SatBlackSport96 said:Anyone comin from the Oceanside area? I'm not sure of the directions, so it would be nice to have someone to caravan with.
weren't you going up there today in the morning?rpraterxj said:I am not sure of anyone coming up from that area. When are you plannig on driving up? I don't the directions from O'side, but if you are going tomorrow morning, we can meet you at the 15/91 interchange. There is an exit right after you transition onto the 91 East from the 15 North. There are a couple of gas stations there. There are a couple of us coming in from OC and we are meeting at 6:30. We should be at the 15/91 interchange about 15 min later.
PM me and I will give you my cell #.
Robert
Kejtar said:weren't you going up there today in the morning?
well if you want to go on a run you have to be at the discovery center by 9am.BlackSport96 said:I'll be going up tomorrow. About how far up is the interchange from here? 6:30's awfully early...I'll see if I can wake up that early...
Bent said:YES. It has been clear and open for at least the past month and a half.
Safe trip gentlemen!
Tim
Hey johnny,xjohnnyc said:I've also decided to go up Saturday morning in order to avoid the Friday night traffic. Remi and I are meeting at the Green Valley exit at 6:30 am.
CMeTopless818 said:It was nice meeting those of you that were at the trail cleanup on Friday.
See you on the trails,
CMeTopless818 ('02 Black TJ-Pebbles)
Why not drill out the hole and put in helicoil?bburge said:Are the threads stripped in the knuckle? Not sure why you need a new spindle if the caliper keeps spitting out the top bolt.
Mine did the same thing. Replacing the knuckle is a pain, I haven't done it yet.
I bought a bolt and nut of the correct size. With needlenose pliers and a lot of cussing, I got the nut in place long enough to get the bolt through the caliper.
There will not be enough space for a washer and you may need to grind the bolt a little shorter to not hit anything on the other side.
Since I will be swapping out my pads soon, i'll get to revisit this whole situation. But I may do the ball joints at the same time.
bburge
