Darky
- 29 Palms, CA
I took the caliper completely off and screwed the bolt directly into where it would go after passing through the caliper and was able to pull it right back out. I tried to use some teflon tape and threadlok and the next day I pulled it right back out again...I've tried with the original bolt (from the bottom since the top one is somewhere on the road) and a new one and got the same results. So I've only got one bolt holding my caliper on.
