2012 build plans?
Getting started on the jeep again, my son has been bugging me to take him out in it.
Have it torn down, here is the plan:
Clean mud off of everything.
Need longer rear shocks, through floor and mount to cage cradle.
Replace anything with a bearing on the front of the motor: water pump, pulleys, etc...
Have a better top made for it.
Add some tube steps/tree rails to the rockers.
Finish tailgate and tonneau cover.
Replace fenders, for the 3rd time. Making some changes to them this time.
May make another hood for it.
I haven't seen it since you de-roofed it, sounds like she's gonna be ready for another swimming session!
Ok so changed some things.
New rubber on at least the front. Maybe all 4 DONE
Tire carrier
D44 up front and 8.8 in the rear swap
4.88s
SYE DONE
Frame stiffies DONE
Full 1/4 armor
RE double shear drop track bar mount DONE
JCR stage 2 sliders DONE
JCR front tie-in brackets DONE
Find a spare tire and rimDONE
Get my cb, antenna installed DONE
Get my fire extinguisher mounted DONE
Intall RIGID L.E.D. lightbar DONE
Hopefully ill have it all done next WF
O and to get rid of the damn wobble!
I like Davidson's format..
I've got a long list...
-Buy 1988 MJ shell: DONE
-Buy 1997 XJ donor (the blue pearl... necklace): DONE
-Dissect 2000 WJ Limited: DONE
-Get WJ body out of the shop - Deadline this Tuesday, then it becomes a coffee table:
-Bring in XJ Donor to harvest dash, seat brackets and some wiring:
-Bribe Gene with leftover XJ donor 4.0 for access to a nice mig and plasma for axle brackets: In Process
-Buy an NVG3550 to either couple to my 4.7 or to my top secret engine:
-Rebuild my NV242:
I'll continue the list on my very first build thread.. hope to start next week. Here's a teaser... Link to pics
fix the hole in the floor board
Gut the interior, and Rhino line the interior
throw her up on the lift and undercoat it so she dont rust anymore
3" lift either Rusty's or Rough Country, cann't decide
replace all steering companents
Get some 31's and start wheelin
Rough country.....
-32-11.5-15 MTR Kevlars
-SYE
-Ironrock Offroad steering
-front axle shafts with bigger u-joint
-Smitybilt 8000lbs. winch
-Novak Cable shift T-case shifter kit
-Roughed Ridge Winch accessory kit
-Rusty's Double Shear Track bar
-D30 Lock-Rite
On the list for later this year another front HPd30 to build and a rear 8.8 with disc brakes
Rough country.....
Rusty's. I've seen a 3" Rough Country leaf pack sag immediately. Thing went flat. Of course they have excellent customer service so they sent out another set right away. Though they're the identical, the owner hasn't put them on fearing they aren't going to fix the problem.
My leaf packs from Rusty's are fawking awesome! Plus they offer you 2 different spring rates for their front coils.
Their springs are fine, i agree but the rest of the stuff is lacking in the actually use it offroad department. The main reason i said RC was because of the warranty.
What is the rest of the stuff?
JIM.
JIM.
Control arms, track bar, all that stuff. THey have gotten better over the years but i'd still go with RC, then again thats just my opinion, don't have to listen to me! :D
-SYE
-D30 Lock-Rite
Search some reviews on the Rustys track bar before buying. I would go with TNT Customs or Rough Country personally.
I've had Rustys HD adjustable track bar since Nov. 03, had to replace the bushings once. Just last week I replaced the threaded end because I slacked on maint. & the jam nuts came loose. Got the fixed UCA & LCA at the same time. Still have the uppers, swapped the lowers to adjustable in 09. YMMV.
JIM.
95: On board air, better gear storage, Idk. Whatever comes along.
97: Things to make it prettier. Hi Country tow brackets. Whatever comes along.
