Where are you guys mounting your fire extinguishers?
5 lb rechargeable Kidd BC extinguisher mounted right at the left side seat base on my driver's seat, and a 5 lb Kidd ABC extinguisher mounted to the passenger rear wheel well (accessible from the back hatch). The one by the seat is for engine fires, and the one in the back is for anything else I may stumble upon.
crazyjim said:
really the 5lb will fit there? Do you have any shots of it? I wouldn't imagine there being a whole lot of room there.
Having two is a good idea though.
Give me a minute, I'll go take one right now.
mine is mounted where the spare tire mount is, never thought about engine fires.. maybe i should mount a second one up front somewhere! :doh:
engine fires dont happen to jeeps. Its not like they ran all the intake, fuel liines and exhaust all on the same side in a small confined area. haha
http://tinypic.com/view.php?pic=10z4adj&s=3
The pictures doesn't show it, but the mount holds the extinguisher in two places, one at the top and one in the middle. I just used some self tapping screws to mount it to the seat base. It's been there for almost four years, and has never come lose when wheeling. I've used it once (car fire on the interstate) and had it refilled.
The one thing to remember no matter where you mount your extinguisher is to take it out once every six months and smack the bottom with a rubber mallet until you can hear the powder moving around. Otherwise it cakes into a ball and the extinguisher is inoperable.
I've got a small one (2lb I think) mounted in the cubby on the rt side of the cargo area. came with its own holster that I screwed into the plastic.
I pulled the plastic trim off of the side of the seat and wedged it there. It fits perfectly and is tight enough I don't need a mount.
Have you actually used a fire extinguisher on an engine fire? I have - I learned that you can pop the hood from the in-cab lever (before everything melts too much), but then you have to release the second catch at the front of the hood. Not good. The heat is all right there. I now carry a set of heavy leather work gloves with my extinguisher, to get at that hood release.
Thought I would update this post with a new mount I got. I am very happy with it.
I backed the panel with a plate. It should hold up until I gut the interior.
