most items i carry that have the label "tactical" aren't completely legal in CA
True, they think they are safe in a communist state. I've got some pre-ban mags I'll gladly send someone to handle the problem :)
he's in 29 Palms-- not the quickest response you can get..... or are you trying to say he might be the thief? That would be wrong (why would he vacation so close to home??) :D
29 Palms is way closer than Nicks house! :D
Could be a good opportunity to test out my new shotgun. :D
:scottm:
Got the Jeep back on the road yesterday. Removed the dead electric fuel pump, cut off the tabs that held on the regulator, sanded it smooth, cut a round piece of aluminum and installed a bulkhead fitting and a couple -6 fittings. Ran a line from the fitting straight down inside that can thing to the bottom for a pickup. Left the screen on the bottom. Put in a universal sender. Now I just need to get my digital fuel gauge installed.
So which wire is the sending unit wire in the plug for the pump/sender on a 97? I could just run a new wire, but why not use what's already there?
The pump wires are orange and black iirc, they are the heavier gauge ones at the bulkhead. The other ones (they go through their own rubber grommet) are the sender. Look at the harness and follow them - they end up going to the ecu not the dash on 97+ since the entire cluster is run by ccd bus, so you might be better off just running your own wire anyways.
Does the stock sender not work?
I knew about the swapped 350, wasn't sure what was left in the tank since he said he dropped the pickup hose down into the metal can thing at the bottom, which made it sound kinda like a stock 97+ sender assembly, just with the FPR bored out and replaced and the pump + filter sock gone. I'm kinda confused about the whole setup :looney:
Just wanted to vent a lil
yesterday was my 22 bday
I got like 7 happy birthday texts/calls
Not a single present not even from the gf
kinda pisses me off considering I bought her a 6k WJ for hers and she got it like a week early
Now I'm sitting at home alone cause we were going to go out to eat but she invited her friend/roommate I can't stand so I didn't go I told her f it I'm not going
good thing I got a 6 pack of BL platinum and a case of ML
Ill be okay
Venting done
I'm putting my Durango box back together after rebuild/tapped hopefully be done tonight
Ill be okay
Venting done
Ill be okay
Venting done
Well damn dude. Happy Belated Birthday. How did you like Harlan? Meant to shoot you a text earlier this week to see how you liked it but wasn't sure when you were coming back.
It was fun a long drive my truck didn't like I think my waterpump is going bad
was a lil dissaponted was able to do most of that place on 35's
but ill be back there though
Harlan? You must not have hit the hard stuff.
Maybe not I was following and I had the biggest rig so.....
was still fun to ride through creek though hopefully I can make the July trip with everyone
Maybe not I was following and I had the biggest rig so..... others had 33the locked fr and alot of body panels still left
