shortxjdoug
- Chattanooga tn
new solid cover= cool
Black transmission fluid= not cool
![p_00029.jpg](/proxy.php?image=http%3A%2F%2Fi34.photobucket.com%2Falbums%2Fd144%2Frcdoug%2Fp_00029.jpg&hash=be8c4a50342d430d0bc6f590ede3f87a)
![p_00030.jpg](/proxy.php?image=http%3A%2F%2Fi34.photobucket.com%2Falbums%2Fd144%2Frcdoug%2Fp_00030.jpg&hash=cbc0caa0fd316c099b46cec9b542354b)
Awesome Doug! But flush the tranny out really good! lol. How'd the trac-bar work out for you?
Went over to ckale1's house to throw a tstat and a water pump on the Jeep after the bearing on the pump got noisy (pump was less than 1 year old). Got everything together and started filling it back up with Coolant only to discover the tstat housing peeing coolant everywhere....apparently that Felpro gasket that already has RTV on it needed more. Took it back off, plastered it in goo and threw it back on...no more leaking
Also swapped the stock fan clutch back on for the rest of winter...i'll probably put the ZJ clutch back on come summer time.
Thanks again Chris for the help...sorry about the coolant all over the floor lol.
how does it drive with the ds out? vibes gone? if so, you should bring it to the boro tonight:yelclap:!!Updated the sponsors page and pulled the front DS to find the double cardon joint is fubared.
No gasket should ever require any type of sealant unless the mating surfaces are not clean. It is far more likely that the t-stat just wasn't properly seated in the recess in the head. I have seen that happen several times on jeeps (even done it once myself), and I have even seen situations where it was so far out of whack that when the housing was tightened, it actually broke the housing. Ask Lil Timmy if you don't believe me lol.
Changed the oil in the WJ, added fresh oil to the air compressor, and then went up and sewed my daughters Disney Princess dress...
Picture a guy in a grease stained shirt, jeans, and cowboy boots working a needle and thread through an Ariel costume!
How is that for opposite ends of the spectrum...
We've got Ariel, and a few others down here....they sure don't hold up too well do they? Little Princesses can be quite abusive to their gowns......:viking:
have you tried this? it helped mine immensely, and with my tires air up to 32psi i get close to 30 mpg on the highway!
http://naxja.org/forum/showthread.php?t=1015963&highlight=adjust+transmission
