- bourbonnais IL
Thanks chico!!
I would be interested in all of these, can you give me a packaged price?A full grey carpet set from the 2000. In very nice shape
Grey seats from the 2000. All are in good shape but the drivers seat has a burn hole in it
Grey head liner, again from the 2000. Not perfect but nothing sagging and could likely be cleaned pretty easily.
If interested in having me bring any of this make me an offer and we'll see what we can work out.
ok i have a few odd ball things
factory tape player, worked when i took it out. came out of a zj. whoever wants it came have it
ZJ tie rod, new tre on draglink end. make offer
air tube with a k&n. not the best but it works, 12 pack of BL
4 shock boots $5
Also have a stock rear driveshaft with a slip yoke still on. U joint on slip yoke end is good. Needs u joint on rear axle end
make offers
I have the back seat out of my '98 (seat and seatback). Gray and kind of dirty, but in good shape in general. Anyone want it?
Pat, I will take whichever 33 is the smaller diameter, need a spare.
LIKEAxles are spoke for, thanks Rew!!
Hey Pat as long as that swamper will mount up on a Beadlock I will take the one Les doesn't take. I would prefer the Stag but which ever.
Cardboard
Anyone have a 15 inch, Black wheel.
American Racing with D slots. Or, Cragar Soft Eights.
I prefer newer or in decent shape please.
BOB
D44 and 9" from an Early Bronco
The D44 front is driver side drop, has 5.13 gears installed. I believe that it is an open carrier, I can't recall, I can pop the cover and confirm. It will need hubs and brakes, caliper cores included.
The rear 9" is low pinion, the 5.13 gears need installed, I have a brand new set of Motive gears for it. Has factory style limited slip. This axle will need brakes also, includes drum brake backing plates.
$700obo, prefer not to separate the pair
Ford C6 (Small block bell housing) transmission/converter with a 4x4 tail housing. It is suppose to have a fresh rebuild, just needs a filter and pan gasket.
I am unsure what transfercase will mate to it, nor what year it came from. Pics available.
$150obo
Dana 300 tcase mated to a Muncie SM465 transmission.
The SM465 is a three speed w/a granny gear, the gear ratios are as follows: 6.55, 3.58, 1.57, 1.0
The Dana 300 Tcase I believe is a CJ version, with a 2.62 low range. It is passenger side drop.
$850obo for the set, WILL NOT separate.
I have a buddy that has this stuff forsale.
For contact, [email protected] will work; Please put "Jeep parts" or something similar in the subject line. Please don't PM me, if you do I will just give you Justin's email address.
They can be delivered to winterfest, or Justin will meet you within an hour or so of Kokomo, or you can come to Kokomo. I can also get them to Fort Wayne if you can't get to Winterfest.
edit: aside from the delivery options listed above, I also travel to Detroit for work almost once a month, so if you're somewhere a long a route that direction from central IN, then a meeting could be arranged.
mac 'swap meet' gyvr
* BUMP *
Still looking! :badpc:
BOB
I will have 4 15x10 black rims once I get my new ones at WF. 80 for the 4
