RoyalXJ
- West Deptford, NJ
I'm getting bored with the XJ and have zero motivation to continue working on it. I'm not dead set on getting rid of it yet but if something else catches my eye its gone. Looking to trade for something else to drive everyday. No cars.
1997 Cherokee Sport 4.0 181k, remote start, snorkel w/ K&N filter, Brown Dog ultra flex motor mounts, Speed Daddy stainless header, Thrush welded muffler (dumped), Magnaflow catalytic converter, Optima red top battery, upgraded injectors, Jeepers N Creepers 62mm throttle body, AW4 Automatic trans w/ flex a lite trans cooler, NP231 transfer case w/ SYE and Boostwerks shift linkage.
Suspension:
3.5" Rubicon Express coils, TNT long arm kit w/ transfer case skid, Daystar extended bumpstops f&r, Iron Rock Offroad track bar and bracket, Rancho 1.5" leaf springs, Ruff Stuff leaf plates, Ruff Stuff 5/8 grade 8 u bolts, Boostwerks orbital 1.5" shackles, HD Offroad no lift shackle relocation brackets, braided stainless extended brake lines, 12" Bilstein 5125s 255/70 in the rear thru the floor with 180* shock hoops, 10" Bilstein 5165s 360/80 in the front.
Steering:
CavFab hi clearance crossover steering, M.O.R.E steering box brace, rebuilt and ported steering box (ready for assist ram), Riot Fab steering box spacer, high volume power steering pump w/ PSC aluminum reservoir.
Front axle:
HP30 3:55, Yukon 4340 chromoly shafts, Spicer 760X joints w/ full circle clips, Aussie locker, new Timken unit bearings, new Spicer HD ball joints, JKS mini LCA skids, Ruff Stuff diff cover, Lube Locker, Synergy 1.25" wheel spacers, Black Magic brake pads, Centric premium rotors.
Rear axle:
C8.25 3:55, Spartan locker, Iron Rock Off-road truss, Ruff Stuff diff cover, Lube Locker, Synergy 1.5" wheel spacers, new drums, hardware and shoes.
2x6 3/16" wall rockers, ZJ gas tank skid, JCR Off-road quarter guards, Dirtbound stubby bumper w/ Barnes 4wd winch plate, Smittybilt Gen2 XRC10 winch w/ Viking synthetic line (3/8"x 100') and safety thimble, LED headlights, 50" curved led light bar w/ A pillar brackets, 5- 35" Goodyear MTR kevlars on Pro Comp 97 series wheels w/ 3.75" bs, TNT unibody mid stiffeners.
Extras: PSC 6" hydro assist ram with lines, Trail Gear 1.5" tube clamp, Rubicon Express track bar bracket with brace, 1.5" .250 wall dom and Ruff Stuff 3/4" heims for a track bar, Boostwerks DIY steering brace kit, KJ rear disc brake conversion (new rotors, pads and brake lines), Ten Factory 1541H Alloy shafts for 8.25, 4:88 gears w/ install kits, Yukon 3:73+ carrier, Aussie D30 locker, Artec inner C braces, Forged U bolt yokes for D30/C8.25, HP30 housing (chopped/boxed coil buckets, Riot Fab OTA track bar bracket, Artec truss & Artec LCA mounts), Complete shaved c8.25 axle.
Suspension:
Steering:
Front axle:
Rear axle:
