Simple Green'd the not so dirty thirty.
I began gutting the housing in prep for the gear/locker install. First task was removing the shafts. Remove the calipers and rotor, and you'll have an up close look at the hub. To remove the hub, you'll need to remove the cotter pin, and lock_nut_thing.
With the cotter pin and lock_nut_thing removed you'll see the hub nut.
The nut is a 36mm, so I use one of these coupled onto an impact wrench to bust them off.
They're torqued on pretty good (220ft/lbs?), and with some rust they can be a PITA to get off. I would suggest a very large (measured in feet) cheater bar, or a good 1/2" impact.
With the hub nut off, you have three additional bolts holding the hub assembly on. They're a 13mm twelve point located on the back of the knuckle.
With all the bolts removed, the hub is free to come off. With this axle, I was able to tap them loose with a hits with a rubber mallet. On Jeepforceone, I spent hours trying to bust them loose, and ended up having to buy some sacrificial bolts to hammer on from the back.
Unit-bearing removed.
You can see the rust was starting to build up. Give it a few years, and they would have given a little better fight coming off. With the hub off you can then pull out the axle shaft out of the housing.
*I should note, if you're just pulling a shaft, you can skip removing the hub nut, and just leave the unit-bearing on the stub shaft. This is where having unit-bearings on your spare shafts, can cut down time significantly on trail fixes.
I have a little more work planned for the housing, but since I was pinched for time this was good enough to get the gears and locker installed.
Loaded up the axle, and the upgrades in the Jeep, and roadied them out to Boring. I should get it back early next week.
Also, much to my surprise I already racked up 3K miles. Time for oil change number two. Oil is priced like gold these days, so I settled on Chevron...
Almost ready to start putting junk under this thing. There's a chance TORX could be ready for a snow run in two weeks.
