Last week I made up some templates of how I wanted my hardline ran. I came up with two lengths of 14 and 45 inches.
I hit up a few of the local parts stores and the closest sizes I could get with the fittings already flared on (I really didn't want to cut and flare) were 40 and 20. In theory I figured I could make them work, and just move the connection point over five inches.
Pre flared lines - $6.
Occasionally I'd make an adjustment to my template, or I'd screw up a bend and have to compensate later on.
Notice anything wrong? Neither did I until I needed the fitting.
I was able to unbend the line, but I never got it back to how straight it was before. 40" was just enough to make the long side line work.
I went to start on the short side line, and discovered I bought the wrong type of flare. I'm assuming this is a bubble flare.
So back to the parts store, and exchanged it for the correct double flare.
Short side started.
A 20" line was just a tad too long. Ideally I should have cut the line, and flared on a fitting at the correct length, but instead I just added an extra bend to take up some length. I'll probably leave it, and if it bugs me I can always deal with it later.
With the hard lines where they needed to be, I had to figure out how to mount the junction block for the soft line. Most axles tubes are tapped for this, or a tab is used. I didn't want to drill a hole in the tube, so I cut a piece of plate to use as a mounting tab. There wasn't really room for a nut, so the plate would need to be tapped. Busted out my handy drill and tap guide to see what size hole to drill for the tap.
Coincidentally, a 3/8-16 tap requires a 5/16 pilot hole.
Tacked on the mounting tab, and test fit everything.
Modified the factory hold down to work at the top of the chunk.
Just need to pick up some new bleeder valves for the calipers, and I can cross the brakes off the 8.8 to do list.
