1997 XJ won’t rev high and loss of power
Gabe22
Indiana
Hello everyone! I am reaching out today for some ideas on this new XJ I have recently got that’s having some issues, but first I’ll start with the background.
Background info:
I recently acquired this 1997 xj from a guy who was just done dealing with it, he just put a new motor in it, radiator, and points + plug wires on it, but it still wasn’t running right, so he gave up and sold it. Apon close inspection after I got it home, I noticed some things were half assed, such as the motor mounts not being secured, and loose bolts on the throttle body. Former owner states he did not replace gasket when installing throttle body, so he suspected it was a vacuum leak.
Problem:
The jeep will idle fine, but doesn’t want to rev up very much, it will rev up more at neutral, but not enough, it sputters backfires with the extra throttle, and barely had enough power to drive up ramps on trailer. The idle sometimes sticks and idles high, but it will not exceed 30 mile an hour before it’s about to stall. It does have an engine light and OBD 2 port, but the port is dead for some reason, and the fuses check out.
Attempted repairs:
So far, I have fixed the loose bolts on the throttle body with no improvement, and checked vacuum lines, I have done the propane test on all of the fittings and seals and noticed no changes in rpm, I also sprayed starting fluid on to the seals of the throttle body at idle and again had no improvement. I’m at a loss for what to do next, so any suggestions would be greatly appreciated, thanks!
Video of it running,
Some things to quickly check...
Check your fuel pressure. Should be around 49 psi at idle. Then rev the engine and hold for a few seconds to see how much the pressure changes. Drop back to idle and check again.
Check your distributor indexing. Given that the previous owner changed the engine, the distributor may be off a tooth or two.
Check the air tube to the throttle body to make sure there's no blockage in it.
With the engine running, feel the exhaust coming out the tailpipe. You should feel some decent "puffing". Rev the engine up and hold for a few seconds. The "puffing" should get stronger. Visually inspect the entire exhaust for any damage (bends, kinks, flat spots).
Did the previous owner buy a "new" engine or rebuilt/salvage? There are no "points" for the ignition.
Is the Check Engine light on? Check for codes (including pending).
If the Check Engine Light is ON, your Jeep is trying to tell you what is wrong. Try another OBD-II code reader and/or fix that fault first.
As suggested already, check the fuel pressure, and distributor indexing
Test the TPS. Clean the Idle Air Controller.
Inspect all the engine bay wire harnesses for chafed or melted wire insulation, failed wire splices or other damage. Make sure Bubba didn't let the wire rest on hot exhaust or sharp sheet metal edges of the valve cover. Check all the wire plugs for corrosion, and bent or pushed back wire plug pins. Don't forget the O2 sensor wires and fuses. 28 year old wire harnesses are prone to age related problems, Bubba done it repairs, and failure from rough handling during engine swaps.
You could also try removing the O2 sensor and seeing if that helps. Idea being you may have a plugged exhaust. Could be a blocked catalytic converter or could even be a shop rag used to plug the exhaust headpipe while the motor was out.
Hello everyone! I appreciate all of your suggestions and feedback, and I have tried mostly all of them with no success yet.
So far, I’ve replaced TPS and MAP sensor, seals on injectors, fixed motor mounts, and grounds.
I’ve tried replacing PCM because I had an extra one sitting around from another jeep, and did not resolve the issue, I did also find leak around one of the injectors too, which was fixed with new o rings. I have sprayed almost the entire top side of the motor with starting fluid at idle and am not finding any leaks.
I am not positive I was able to check indexing right, but after viewing the spark advance at idle I would suspect it is good(let me know if I’m wrong data is in video below)
I know the alternator is not charging and it does not like to run when the battery is low, I doubt that this issue has anything to do with the main one
I did not check the fuel pump pressure at the pump, but at the rail, it sprayed gas all the way out of the engine bay so I would suspect pressure is reasonable, I will probably pull the tank and check next just been dreading it.
It is slightly better I think now than it was when I started, with the o ring on the injector replacement helping the most.
One of my friends said it may be something to do with anti theft mode, but I don’t believe they had those in 97.
I did find out the jeep is a 97 and the motors from a 95.
I cut the exhaust off so it should be breathing freely except for the slight bend in the exhaust by the header which I found to be normal according to online.
I’m at a loss as to what to do next any feedback or suggestions are greatly appreciated, and I want to thank you all for your time of reading this and responding.
Link to live data from scanner:
YT OBD2 LD link
I have read somewhere that the flywheel on a 95 is different than a 97 so I wonder if that may be the issue as 95 was pre obd2
The scan tool isn't going to tell you if the distributor is indexed correctly, or or the plug wires are in the right spot. https://cruiser54.com/?p=68 I would verify the distributor indexing and wires are correct, as well as confirm good fuel pressure. Have you done a compression test to rule out other issues?
Test ODB-II sensors. Brand new does mean that the new parts are good. Chinesium sensors are often out of specification or even DOA right out of the box,
Continuity test the from each sensor to the PCM. Inspect all the engine bay wire harnesses for chafed or melted wire insulation, failed wire splices or other damage. Make sure Bubba didn't let the wire rest on hot exhaust or sharp sheet metal edges of the valve cover. Check all the wire plugs for corrosion, and bent or pushed back wire plug pins. Don't forget the O2 sensor wires and fuses. 28 year old wire harnesses are prone to age related problems, Bubba done it repairs, and failure from rough handling during engine swaps.
Bucking, stalling and/or backfiring are O2 sensor symptoms. Bad snesors, Bosch or geric O2 sensors from the part statore, O2 fuse blown, or wire harness defects.
1997-01 anti-theft kills the engine after 3 seconds of running. If the engine runs at all, the flywheel is probably correct.
