- NE Texas
Are you sure a Tera-60 will hold up to 35s?
For the time being, yes. Ground clearance isn't even a worry with the Tera housing. In fact it'll be better than the 8.8 and 33's. Plus it should be a pretty bulletproof setup.Looks very nice! Are you sticking with the 35's?
They're actually a stock 8.8 disc setup. They are a bit lower though, and I think that just has to do with the way the outer flanges were welded on. If they're an issue, I'll just go to a weld on caliper mount and clock them up.I`ve never seen Calipers on the bottom. Seems like they would have a chance of damage and being drug .
Post #474.Is that an off the shelf gas tank skid? Or did you make it?
On my 8.8, I made some custom mounts to basically mount the shocks flush with the bottom of the axle tubes. I knew this would cut into my uptravel, but I was willing to sacrifice it for clearance (I've seen so many people get hung up on the boat anchor stock mounts). It was a tradeoff, and with 10" travel shocks in the rear I only had maybe 2" of uptravel.I like your setup, but have a question about the lower shock mounts. They're raised up 3-4 inches above what they could be mounted on the lower half of the axle tube. It seems like you'll have to run a short body shock if you keep the upper mounts in the stock location. Is this your plan? Or are you gonna put the shocks up through the floor?
High pinion, 19" to the bottom of the rear yoke. The driveline isn't even visible from a side profile.Good work duderino. I dig it. Is that a HP60 or just a tilted up lp60?
Are you new here?Looks good so far dustin! I'm really digging how those front stiffeners came out. Are you building your own for the middle or buying them?
Missed you in Moab this year Dustin, but I can understand why with all those sweet parts waiting to be installed. The new build looks good, I am envious of your patience and attention to detail to crank out clean work.
