THe NAC Lots-O-BFG KO2 Thread
TEXT TEXT TEXT!!!!!!!!!!
There's not something different about the 35 yoke?
From everything I remember the 30/44/dana300/etc are all the same but the 35 doesn't interchange.
(inside reference: Matt Gaskins having to punch broken strap bolts out of his rear 35 yoke in the Woodpecker after breaking them in the Backyard in '07 because everyone only had 30/44 yokes available)
AFAIK No.
J0935685
Spline Count: 26
Seal Surface Diameter: 1.552"
Seal Surface Height: .662"
Designed for a 1310 U-Joint
Overall Height: 3"
Spline Length: 1.552"
Slinger Diameter: 4.150"
It's at my desk now. Let me know if you need any other measurements.
Dana 35's have a 1.842" diameter through the seal.
30/44/300/etc use the 1.552.
Not sure what else changes though.
Makes sense. We do include a seal with our D35-YOKE-UBK. Spicer P/N: 40554
So what do you guys think of this? Gonna cut the soft lines on both sides of the hard lines, gonna use some hose barbs and some rubber hose to replace just the hard line section, should work mint, plus it ain't like this this flows a lot of fuel
Do it, should be no problem at all. Very little pressure in those lines.
Use power steering fluid or ATF for brake fluid while you are at it, I hear it works great
THe NAC Lots-O-Post Thread
I need to buy a tranny cooler before NACFest. Any recommendations?
AX15s don't need hose barbs, and they never came on Exploders you goof
:twak:
Go the JY and grab one off a Ford Explorer.
Usually dirt cheap, have 3/8" hose barbs right on them, and work very well.
x2. That's what I used. I just cut and flared the tranny lines and ran hose to the cooler. I mounted the cooler with the zip-tie style mounts.
https://www.etrailer.com/Accessories-and-Parts/Derale/D13001.html
