- Torrance, CA
then why does he feel so right?Ken is wrong.
In many, many ways.
Will they be available in 8 lug or only 5/6 lug? I read that as heavy duty hubs for 5/6 lug 44s, not hubs for 8 lug hd44s, hopefully I am wrong
The hubs that have problems are the 5 lugs. The 6 lug stuff is way thicker and doesn't generally suffer the same issue the 5 lug D44 hubs.
Exactly what 'issues' are you referring to? I swapped from 6-lug to 5-lug.
They swell and everything gets jammed in the hub. The 6 lug chevy hub is way thicker and resists this issue.
The hub itself swells? As in compresses the bearings?
This must be an issue in 'go fast' situations.
I'm pretty sure mine never get's hot enough to swell.
We need bigger Yukon stickers.....
Hahahaha!I know of a few stickers you can remove to make space:laugh:
Actually, only 10. We're the 11th car off the line.Only need to pass and stay ahead of 11 racers! No problem, you guys can do it!!!
No more testing scheduled. The next time we drive the car will be to pre-run the course in Feb.
Going through the axles, checking and torquing every bolt, having new window nets made and painting the car. We added an anti-rock and will add some more lights, but beyond that we locked down any additional changes. Time to race!
