Not much dialog, I'm beat..
These Stage 8 spindle nuts are amazing! Thanks to RedHeep for donating a pair to us!
New secondary door latches. Can be locked with a pin or a 3/8 bolt.
Ultimately the pins will be on lanyards so they don't get lost, but we didnt have the supplies on hands.
The mad scientist decided we need a tach in the car. Now when you're revved up and think its about to blow, you can look down and see that theres more to give.. ;)
New vent line for the fuel tank. 1/2" clear from the rollover valve up the fill hose and back down to a ball valve, and 5/8" black rubber hose from there.
The hose runs down under the tank to the passenger side, and then out the rear of the car.
Are you guys running a speedo?
XCM doing a little body work before we paint.
Kitty!
The only thing a speedo would do is frighten the codriver, and tell you how fast the wheels are spinning - which isn't always how fast we're moving.. :)
The GPS records top speed and average speed, but I don't have it setup to display speed while in motion.
XCM hopped in the car and took it for a spin around the block before we tore it down.
A little Cardboard Aided Design for window net templates
Puppy!
A little primer..
Heat treated parts are stronger right?
The funky little mouse ear plate there will have a rear view mirror on it.
Winch controller securely mounted with regulation zip ties..
Great pics! Thanks for posting them, and letting us live vicariously through them.
David Bricker / SYR
