cabz
- Maynardville TN 37807
you definatly need to cure the vacuum leakson that old renix. have you replaced the o2sensor andor the tps? . o2 sensors go quite regularly on renix jeeps. mine never went out of warranty before it needed replaced again.
also when you set the renix tps , setting it by voltage work ok for a baseline to get it going
but try and get a scanner on it to get it set right. also any change sensor wise , disconect the battery and let the ecu reset sometimes the high idle issue will continue even if the problem is corrected because the ecu does not auto correct.
