I have an AMC Eagle running a 1990 RENIX 4.0 that is stumbling from idle to 3ooorpm. At 3ooo it literally takes off like a rocket until you drop below that RPM.
At idle it’s pulling 26* of timing and the light is not jumping around. At 3ooo it’s a steady 35*
When it acts up it will misfire and backfire thru the intake and pop thru the exhaust.
TPS is brand new and properly aligned.
IAC is newer and cleaned.
CPS is brand new from Hesco
MAT sensor is new
MAP is new and properly installed
Fuel pump and filter are new. Pressure is between 32-40 depending on RPM.
FPR is new
Have tried with 02 hooked up and disconnected.
I’m beyond stumped. Car was sitting for about a decade before I purchased it.
MAT sensor is new
FPR is new
