Renix Computer Demon
Check the connector at the firewall for the cps. I've had to unplug and plug back in this connector a few times on a no start.
If your tach isn't moving whilst cranking, cps is suspect. Good luck
Also there was an upgraded wire harness that bypasses the loom and goes cps directly to ECU
Do you have a link to information on the harness change/modification?
I posted this earlier.
You can read the entire TSB from the link inside that post.
However, this TSB doesn't apply to your XJ as your year does not have the C101 connector.
Got it. Thank you.
The manual says this to test the CPS
"Speed Sensor (Crankshaft Position Sensor-CPS) Test
Disconnect the speed sensor connector from the harness. Place an ohmmeter across terminals A and B (marked on connector). The meter reading should be 200±75 ohms (hot engine). Replace sensor if readings are not to specifications".
