- Harrisburg, NC
You're trying to de-redneck it, and it's not happy! It wants to be a redneck-mobile!
possessed?
I had low idle problems on my 90, it turned out that the HO valve cover/CCV that I put on had too small of an orifice in the CCV elbow. It took me 2 years and threw all kinds of parts at it only to find out by chance that I needed to make the CCV orifice bigger to bring the idle up! It went from 600rpm in park to a smooth 850rpm by just making a controlled vacuum leak bigger
RENIX is a moody old beotch.
I think you have a issue in your IAC circuit somewhere. Figure out which wire in the lead is the ground and T another ground to it. Also, check the latch relay, it resets the IAC on shut down for the next restart. Look/test for vacuum leaks, any air introduced post TB will lean out the mixture and raise the idle.
5-90 and Cruiser54 are two of the best I know on here with RENIX and have helped me tremendously with mine over the years.
My son's MJ is acting up today. It revs to 3k and is hard for him to keep under control. I have to give it a look tomorrow but i thinks its mostly this really cold weather.
I've brought a disease into the family!
Yeah it's really hard to drive when it stays at 3000. the MJ just wants to run away
I just put a motor in it two weeks ago so it may have something loose. I dropped a 98 long block in. I used the RENIX intake/exhaust, i might have a intake leak.
We keep having the same thoughts. Driving it today I didn't remember the exhaust leak sounding so bad when I brought it home.. I hit the top bolts and a few were loose... Got distracted and forgot about the rest. I'm going to have some serious mixed feelings if that's it.
I chased mine for 2 years. I'm pretty sure it ended up an exhaust leak.
My exhaust leak is bad. I had no power on the highway today. I have the gasket need to get the fuel line prongs from the dealer, make space in the garage and it's happening.
What are these fuel line things you speak of?
Don't know why I said prongs... They have a neat kit with the orings, spacer, and quick disconnect clip all on a plastic installation tool.
Oh so you are referring to the quick disconnect on the fuel rail?
Yes sorry poor communication on my part.
