SmokeyTheRedXJ
- Fontana CA
I want to make this post to clarify the Renix coolant sending unit and sensor (have also seen it called a knock sensor. I need this information currently so it will help me as well as others because it is so mixed and scattered.
The coolant sender on the back of the block is the one that sends the temp to the gauges. That one every one seems to agree on and is okay with. If any one has a part number it would be nice to have.
The other one is on the driver side kind of down on the block closer to the front. This one is the temp sensor and it sends the coolant temp to the pcm which also plays a part in the high idle problem it seems a lot of people have. Does anyone have a proper name for this, as well as a part number. This is the one I need to currently replace.
Thank you
Thank you
