1990 Wagoneer auto, 4.0 Renix. I have been chasing a damned demon in my otherwise excellent condition Wagoneer. Randomly, the Jeep with stop running and will then crank but not start. Past episodes were remedied by disconnecting the battery and reconnecting, or disconnecting the TPS and reconnecting. It happened today and nothing would get it to start. When this happens, the fuel injectors are not firing. The rail has pressure. After 20 minutes today, it decided to start right up.
I have performed the fillowing:
New StandardMotor Products TPS
Cleaned, checked all harness connectors
Inspected sensor ground
Added additional ground cable from engine to firewall
Added new ground cable from battery to radiator shroud
Installed new 2 awg battery ground cable and cleaned all terminations
I am baffled. I have driven a couple hundred miles with no issues and then this happens out of the blue. Any thoughts on this?
