RCP Phx
- Phoenix,Az
You are correct,thats why its so obvious your angles are off!boomhauer said:You have to look a the mounting point, not where the bar bends in order to determine angle. -B
![2285723310093170617S600x600Q85.jpg](/proxy.php?image=http%3A%2F%2Finlinethumb59.webshots.com%2F40954%2F2285723310093170617S600x600Q85.jpg&hash=5e880b66693e651b939324f147780f07)
RCP Phx said:Why buy it then?
If you want an OTK set-up there are plenty of other excellent set-ups out therethat are designed for that exact purpose!And a hell of alot cheaper!
RCP Phx said:You are correct,thats why its so obvious your angles are off!
MiNi Beast said:Yeah your trac bar and draglink are to be parallel, so the track bar would need to be mounted over the axle to match them. But a drop pit man arm will bring it closer yet with what you got with out moving the track bar.
A drop pitman arm will make the angles even worse!MiNi Beast said:Yeah your trac bar and draglink are to be parallel, so the track bar would need to be mounted over the axle to match them. But a drop pit man arm will bring it closer yet with what you got with out moving the track bar.
RCP Phx said:A drop pitman arm will make the angles even worse!
Because the angles are good.Well Rockkrawler is considered one of the better companys out there!They Designed it and built it to be installed per their design in order for it to work correctly and give the benefits it was marketed for(Full crossover and greater clearnce) and trackbar relocation not required
Why buy it then?
RCP Phx said:Because the angles are good.
Yup, that is my point. I wasn't happy with the 'recommended' system, and now i am.-B:woohoo:MiNi Beast said:Run it. If she runs stright and no bumpsteer and you like it and then run it. If it works then it works.
Anymore reports on this? I am thinking about picking up a used X Factor system, and was wondering if anyone had anything to say whether or not it limited droop in anyway?
Actually no they aren't. Think of it this way, the tracbar is mounted at the same height as the center of the mounting point of the knuckle; draglink on top, tierod on bottom obviously. Now, maybe the photo is a bit discerning, but the upper tracbar mount is higher and right of the (dropped) pitman arm.
