Vanimal
- escondido, ca
i had an idea, i can make a plate and bend all 4 sides down to make sort of a shallow box, and weld that in the same fashion that i would using angle iron. then the top would be double the thickness and i still have a flat area to bolt the cross brace to. since the shock tower is all nominal dimensions, i'm pretty sure my buddy has a die the proper length to bend in between the other two sides of the box for his brake press.
