Vanimal
- escondido, ca
got the new axle tubes turned and pressed in for the high pinion dana 44.
turning the od of the tubes down about .04" to match the factory tube diameters so i wouldnt have to bore the housing or inner c's
boring out the id of the tubes for the axle tube seals
i froze the tubes in the freezer for about an hour, and heated the housing in the oven to 250f. the tubes were really easy to tap in with a mallet. since they went in so easily, i'd be pretty suprised if they were crooked at all, but i will still check.
i picked up some nickel rod, so i just gotta burn them in and install the inner c's and various brackets. hopefully get this sucker up to John tomorrow for gear install.
