jcnoble
- Huntsville, AL
88 XJ Rustys 4.5" lift. I hae always had death wobble problem when hitting potholes. I set toe in and adjusted teackbar. I am using the caster alignment procedure found here. It reads 0 degrees without the 9 degrees it says to add. Does that mean i am +9 degrees or - 9 degrees. The uca Rusty furnished is 16", lca is 16.75. The chart on this site says uca s/b 15". To me that means i am + 9 degrees. Which means my axle is rotated in the wrong direction. Caster s/b at about -5 degees. Which i had a diagram to show u. If looking from drivers side shouldnt the axle be rotated clockwise about 5 degrees. Mine is rotated counter clockwise ~9 degrees according to chart found on this site. To me it seems i need a shorter uca.
