maxbraketorque
- PDX
As part of a front axle swap, I completely disassembled the RC 4.5" long arm front suspension on my XJ, and then put it back together with a few changes. A couple of comments on optimizing the setup:
-- Switching from a fully linked radius arm to using just one short arm (on the driver side) greatly increases the flex compliance of the front suspension. Easily can tell the difference even on the highway. I know I've already mentioned this in another thread, but figured I'd consolidate it here.
-- There is room to make the long arms 1/2" longer than specified by RC. This increases tire clearance to the back of the fender well. A few mods are needed. First is that the sway bar needs to moved forward to keep from hitting the springs. Second is that the rib on the back of the RC track bar mount needs to be trimmed to provide clearance to the coil springs.
-- No front (or rear) bump stops are provided. RE1380 2" bump stops do the job for the front and are cheap.
-- The primary interference point during full flex is the driver side coil spring perch on the axle hitting the track bar mount. If the axle is centered at ride height, these pieces will collide a few inches before reaching the true limit (where the long arm hits the unibody rail). This happens because the RC track bar mount is really long. Its 1/2" longer than any other's I've found. Even with the axle shifted over to the driver side to make room, there is still some chance of collision because the track bar bushings are so squishy which can allow the axle to shift. Trimming the track bar mount along with shifting the axle slightly is the driver side is the most reasonable solution. There are no issues when flexing the passenger side to full compression.
-- The track bar bushings are very squishy. My solution was to install OEM JK track bar bushings that are set up to use 9/16" bolts. Requires slightly opening the holes in the track bar and of course drilling the mounting points for 9/16" bolts. Still some squish with these but a lot less than the RC bushings, and now I have 9/16" bolts at both ends.
