- Terra Firma
Refer to the diagram Langer1 posted above.jcnoble said:Here ya go.
http://go.jeep-xj.info/HowtoAlignment.htm
The toe in procedure works good, I am still tying to figure out the caster measurement.
Your understanding of positive and negative caster is backwards. Caster is what used to be catted "kingpin angle" when front suspensions had a single kingpin that ran from the upper yoke to the lower yoke. Now we have an upper ball joint and a lower ball joint. The caster angle is the angle of the imaginary line that connects them. Caster is positive if the upper ball joint is farther back than the lower (as pictured in Langer1's illustration), and negative if the upper ball joint is farther forward than the lower.
What GoJeep has done is document the fixed relationship between the differential housing and the steering knuckle. Once you know the difference between the two, by measuring the angle of the differential housing you can calculate the caster angle directly. Remember, the knuckles are welded to the axle tubes, and the exle tubes are pressed and welded into the differential, so if you change the caster angle you simultaneously change Dke angle of the`lifferential hodqing (a>a phnion%shaft)@dy the same amount.
