dieselenthusiast
- Zuni Mountains, New Mexico
Diesel, you've really built up your toy, haven't u? nice!
And with your help!
And with your help!
Any chance we can get some recent pictures of the Jeep? Anxious to see how the total picture looks inside and out. Have really enjoyed the read so far.
In the above picture, you can see how tight the turning radius is, plus the Jeep’s spare tire is a nuisance when trying to lower or raise the jack stand. There’s not not enough clearance to swing the jack stand handle without hitting the spare tire. To remedy this problem, I’m adding a hitch extension to extend the ball mount past the spare tire. The longer extension should also reduce jackknifing when I need to make tight turns.
I went with a heavy duty hitch extension with dual receivers. I “think” I have a plan for the dual receiver, but I’m going to save that discussion for another day.
Roadmaster Dual Hitch Receiver
Dual receivers have 2" x 2" openings
Towing Capacity: 10,000 lbs.
Tongue Weight: 400 lbs.
Cost: $94.95
That hitch extension will drastically increase the moment (torque) that the tongue weight subjects the bumper/receiver to. I don't have a ton of towing experience but from an engineering standpoint, I feel like those two other options might be a better idea.
Actually, there’s very little ill-effect from using a hitch extender. I’ve seen them up to 34” in length. The one that I bought is only 14 ¾” in total length and 10 ¼” from hole to hole. Clearing the spare tire was only one reason for getting the extender. The extension also allows me to take tighter turns. The bigger issue to towing is to make sure your trailer is level and the load on the trailer is equally distributed.
As for carrying such loads, I built my lift to accommodate the extra weight of the rear bumper, tire carrier, and to enhance towing purposes, hence the extra OME add-a-leaf in the rear.
For your situation, towing lighter loads, there probably isn't too much of an issue with a hitch extender.
To say there is very little ill-effects of using hitch extenders is far from the truth. They reduce the overall acceptable tongue weight, they increase side loads during turning and emergency maneuvers, and they put much more stress on the already weak OEM hitch. I would never consider using a 34" hitch extender nor would I want to be on the road around someone using one. For heavy duty towing, you would really need something like a Torklift Superhitch.
I have the same bumper minus the tire carrier. The extender would be worth it if for no other reason than the pita of hooking up the hitch and hooks with that bumper.
where did you get the mount for the CO2 tank? ive been looking for one for mine.
After looking at many steering manufacturers, I ended up choosing Currie. Their kits are 100% bolt-on and designed to work with the OE pitman arm.
Currie Currectlync Heavy Duty Tie Rod and Drag Link System
Part #: CE-9701
The Currie steering has arrived.
