mhead
- Encinitas, CA
1992 4-door Jeep Cherokee XJ with 4.0 6 cyl engine and AW-4 auto trans.
Date of purchases 2023AUG
Userful
reference thread
https://www.naxja.org/forum/showthread.php?t=1100177&highlight=air+conditioning
The project goal was to replace all A/C parts, except the evaporator, with new and to convert system from R-12 to R-134a refrigerant. The project took several months with various shipping delays and incorrect parts orders. The list here in this post should shorten the overall time dramatically.
I used Youtube extensively to learn how to install and charge. Prices are what I paid not including shipping. The total project ran about $800 but now I have the tools for future use.
Refrigerant flow in this system is... compressor, discharge hose, condensor, liquid hose, receiver-dryer, liquid hose, expansion valve, evaporator, suction hose, compressor. There is a pressure switch on the receiver-dryer.
I was able to purchase all replacement parts except the liquid hoses. These I constructed myself since I could not find a local shop willing to do this task.
All replacement parts were drop-in matches for existing parts. No special mounting or other efforts were required.
The original receiver-dryer supplied in the Parts Geek kit uses an obsolete fitting so a replacement receiver-drier must be purchased. The replacement uses standard #6 fittings.
Jeep repair threads encourage the use of a PARALLEL type condensor. I found and purchased condensers that were described as PARALLEL. All were in fact series (serpentine) and all were returned. In the end I simply used the series condensor that was supplied with the Parts Geek kit.
The condensor in the Parts Geek kit arrives with short tubes that route refrigerant around the side of the radiator. I removed and discarded the short discharge tube since the Parts Geek discharge hose also has routing around the side of the radiator.
The original compressor and the Parts Geek kit replacement compressor were identical and are Sanden International SD-709. I replaced the original valves on the back of the compressor with R-134a fittings.
Since R-134a refrigerant uses a different compressor oil, the evaporator must be flushed. I flushed the evaporator. The flushing agent dries slowly. After flushing I arranged a fan and funnel to blow air as best I could through the evaporator. After several days, blasts of compressed air into the evaporator no longer caused it to cough up liquid flusing agent.
Original compressor had a tag showing charge of R-12 of 2.38 pounds. R-134a is lighter and so less R-134a refrigerant is required. Several internet sources give this formula for conversion
R134a charge (pounds) = (0.9 * R12 charge (pounds)) - 0.25 (pounds)
So R-134a charge is 1.9 pounds or 30 ounces.
Jeep FSM states 135 ml oil should be in the system. Besides the compressor the remaining system is all new or flushed so no oil is in the system. Compressor arrived with a tag stating 180 ml of oil (PAG for R-134a) was already in the compressor. I drained and discarded 45 ml oil, leaving the required 135 ml oil within the compressor. I next drained about 50 ml oil from compressor and poured this into the condenser to initially distribute oil in the system.
I vac'ed the entire system for more than an hour on multiple days. After several days I checked the system to be sure that it held vac.
I purchased 3 X 12 oz cans of R-134a. Charging the system went well and is described by several Youtube videos. I put two cans completely into the system. I weighed the last can, then filled the system until weight was reduced by 6 oz, giving 30 oz total charge.
Be sure to CAREFULLY, with magnifiers, inspect every seal prior to joining. I found a leak in a Schrader valve due to a bit of metal, bits of cardboard in refrigerant can openings, poorly manufactured seals on receiver-dryer, and various bits of metal in bad places. No one is watching the manufacture of these parts.
Prices do not include various mistakes I made in ordering incorrect parts. Mistakes added about $100. I could have been more cost efficient with tools and should perhaps have ordered the Parts Geek kit if I had known the part numbers of included items...
Cold Hose and Jeep Air are in fact the same company. Perhaps they will consolidate orders for the purposes of saving on shipping.
SUMMARY
Special Tools & Equipment
Lichamp R134a Can Tap $10.79
https://www.amazon.com/dp/B0B33CDLF3?psc=1&ref=ppx_yo2ov_dt_b_product_details
Aupoko R12 R22 to R134a Adapter fittings $8.99
https://www.amazon.com/dp/B07PXJYB3C?psc=1&ref=ppx_yo2ov_dt_b_product_details
Foifatt AC Flush Kit $31.99
https://www.amazon.com/dp/B094QQTQ51?psc=1&ref=ppx_yo2ov_dt_b_product_details
AMZCNC 71500 Hydraulic A/C Hose Crimper $129.88
https://www.amazon.com/your-orders/...rtIndex=20&ref_=ppx_yo2ov_dt_b_pagination_2_3
OMT AC Gauge Set $35.99
https://www.amazon.com/Orion-Motor-...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Vacuum pump (I already had this) $70
Total Special Tools & Equipment $288
Materials
FLUSHING AGENT
TSI Supercool FFQ High-Temp A/C Flush $17.95
https://www.amazon.com/dp/B00CFQQX5S?psc=1&ref=ppx_yo2ov_dt_b_product_details
REFRIGERANT
Chemours R134a Refirgerant $33.49
https://www.amazon.com/dp/B088HGRJ3Z?psc=1&ref=ppx_yo2ov_dt_b_product_details
Total Materials $51
Replacement Parts
COMPRESSOR, CONDENSER, EXPANSION VALVE
UAC A/C Compressor Kit $272.43
Parts Geek 2227-05980682
https://www.partsgeek.com/catalog/1...fs-c_compressor.html?rp=a-fs-c_compressor_kit
Compressor UAC SD7H15 CO7701C in this kit is identical to compressor in my Jeep. Both are Sanden International SD-709
Did NOT use Receiver-Dryer or PAG oil supplied in this kit.
Condenser UAC CN 4174PFC SX 2203UL
Expansion Valve UAC EX 9448C
RECEIVER-DRYER
Cold Hose Cherokee R134a Drier 22-8264 $29.99
PRESSURE SWITCH
Cold Hose 10mm Female Binary Switch 11909886 $19.99
Santech MT1366
VAPOR HOSES
Four Seasons A/C Refrigerant Discharge Hose 56279 $47.43
Parts Geek 2227-05318138
https://www.partsgeek.com/catalog/1992/jeep/cherokee/climate_control/a-fs-c_hose.html
Four Seasons A/C Refrigerant Suction Hose 56278 $38.43
Parts Geek 2227-05318137
LIQUID HOSES
Construction of Condenser to Receiver-Dryer liquid hose:
Cold Hose #6 (5/16") Standard Barrier A/C Hose, 9", BH6 $3
Cold Hose Custom 90 degree fitting $60
(two 90 degrees S seperated by 5" – see the original in your vehicle)
Cold hose #6 Straight O-ring Fitting BL1301 $6.72
Total 69.72
Construction of Receiver-Dryer to Expansion Valve hose:
Cold Hose #6 (5/16") Standard Barrier A/C Hose, 16", BH6 $5
Cold Hose #6 90 degree O-ring Fitting BL1321 $6.57
Cold Hose #6 Straight O-ring Fitting BL1401 $6.72
Total 39.57
MISC FITTINGS REQUIRED
R134-a Fittings for compressor
Jeep Air Tube-O Compressor Suctin & Discharge Fittings with R-134a Ports $26.99
FT0168-FT0169
https://jeepair.com/collections/fit...ings-with-r-134a-ports?variant=32066979561557
Total parts: $523
Userful
SUMMARY
Materials
FLUSHING AGENT
REFRIGERANT
Total Materials $51
Replacement Parts
RECEIVER-DRYER
PRESSURE SWITCH
Santech MT1366
VAPOR HOSES
LIQUID HOSES
Total 69.72
Total 39.57
FT0168-FT0169
Total parts: $523
