iluv83vettes
- Houston
It can make the battery lose its "holding power" a little faster.
It wont be a "quicker" charge, it just means the alternator will hit peak output at a lower engine rpm but it would sap more horse power to turn since you're essentially putting taller gears on it.You are correct. The key is to have a proper functioning PCM. Thanks for pointing that out. Here's my question: Will a quicker charge have any ill-effects?
Just curious... what's your oil pressure at idle after Jeep reaches operating temperature?
You could always drill a small hole in the extra ribbing of the cap and use a small piece of wire to tether the cap to the jeep.![]()
THIS is a good investment for a DD Expo type rig.
http://www.blackmagicbrakes.com/
XJ 4WD 00-01 Front Black Magic Brake Pad, Calipers, Rotors
KIT: Jeep XJ 4WD 2000 – 2001
Cost: $290
Includes parts for both Passenger and Driver sides
•Front - Black Magic Brake Pads
•Front - Stock Replacement Premium Zinc Plated Calipers
•Front - Centric Premium Rotors
Wow $165 for brake pads.
Living at 7,000 feet poses a few challenges with cold weather being one of them. We’ve seen temperatures as low as -29. For this reason, we have OE block heaters on all of our vehicles for easier startups and quicker warm-ups. Initially, we had to lift the hood on the Cherokee whenever we wanted to plug in the block heater. Two years ago, I decided to reroute the cord to the front of the grille. The new location made the plug accessible for easier operation; however, the cord dangled from the front grille which further exposed the cord to the elements. So, I decided to find a better solution. I’m going to use a Marinco 150BBI Charger Inlet.
