831_xj
- Santa Cruz
Yeah buddy! That's so rad good work
Rustoleaum hammerite black
Hammerite black it is! Thanks for the input fellas.
Does anybody here have experience rebuilding or drilling/tapping a steering box for hydro assist? I've spent pretty much the past 7 hours messing with this J20 box I got. I tore it all apart, tapped it, and have had a heck of a time putting it back together. The issue is with the worm gear and the associated ball bearings. I worked the input shaft back and forth while dropping in the ball bearings until they were all in. But once they are all in, if I cycle the input shaft from lock to lock, some ball bearings keep falling out to the front side of the piston, limiting how much it turns to the left. Also, the input/worm gear/piston keeps binding up. Right now the worm gear is bound up to the point that I cannot move the input to the left or the right. It won't budge.
Any ideas or input? At this point I'm thinking that my new box is toast and I'll have to buy another one.
About the pump, I was doing some research and came across this: http://www.naxja.org/forum/showthread.php?t=946090
They are using 2001 4.7L Grand Cherokee PS pumps in our XJs. They have more pressure and higher flow due to the fact that the PS pump also pumped fluid for a hydraulic cooling fan. The OP of that thread said you just have to swap out the high pressure fitting and plug the extra low pressure return line. This setup might be something to consider.
