Mike1331
- Folsom, CA
Full widths say what? Last I checked he was on stock axles. What'd I miss?
He has them in his garageFull widths say what? Last I checked he was on stock axles. What'd I miss?
so this is my serious two cents. if you go 37's you won't have any more room in your fender to flex more so that could help u out. also have you thought of those sliding shackles? I've heard they slide farther back so that your spring only zeros out and not negative.
this makes me wonder what mine is doing...
So i am facing the same scenario minus the breaking of leafs. Almost all of your lift is coming from the shackle and relocators. As is mine. Im swapping to the nolift relocators and a 5" shackle(instead of the 9.5" shackle). Then some more arched leafs with a ladder bar. Later down the road shocks through the floor.
Kevin you are not considering 37s on those axles ?
What about adding another leaf and raising the shackle hole up?
